Wheel size
Nismo3.5
Car: Altima 3.5SE
HiI'm new here so i don't know if the question has already been answered.I wanna change my 17' wheels on my Altima and i was wondering what's the maximum size to put onI know 18x8 fits but can i go to 18x8.5 or 18x9 depending on the front or rear wheels??I have an 1" Eibach drop i don't know if that changes anything.Thanks for your answer!
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
18x9 should fit no problem as long as you have the right offset. try to keep the offset around 45 (same as stock). there's a member who has 10.5" rims on his rears and doesn't rub, but he has a pretty high offset
Nismo3.5
Car: Altima 3.5SE
Thanks for the answer and i guess i can put a bit larger for rear ??Does the drop changes anything ??
BlackMamba08
Car: 2008 Nissan Altima Coupe 3.5SE
As for width...you could run 9.5 "safely" if you have the right offset, nothing too insane, you can also "safely" run 20s on the coupe. I am running 20x8.5 with a +35mm offset.
White_SR
Car: 2010 Altima Coupe 3.5 SR (CVT)
BlackMamba08 wrote:As for width...you could run 9.5 "safely" if you have the right offset, nothing too insane, you can also "safely" run 20s on the coupe. I am running 20x8.5 with a +35mm offset.
What's a safe offset for 9.5 width? Would +38 do it?
Oilsink
Car: 08 dark slate
yea +38 should be good, just dont get anything higher than a 45 series tire.
White_SR
Awesome thanks, was thinkin of goin 255/35-19
Sorry for thread-jackin ya Nismo3.5!!!
Nismo3.5
Car: Altima 3.5SE
No problem,
i was wondering is that the same for the 4 door sedan ... 9.5 would fit??
alphapig
Car: Nissan Altima Coupe S 2.5
Nismo3.5 wrote:No problem,
Yep
I have 18x9.5 +35(effective) in the rear.
Nismo3.5
Car: Altima 3.5SE
I finally found my wheels ... i got a good deal, i exchanged me 17" oem for the 18X8 maxima/350 wheels, the tires on are 245-45-18. For that price i could not refuse.Now if spring can arrive, so i can put on those 18"
