Wheel Size?
grffnsmth
I'm looking to get the Tenzo DC-6 Version 1 rims and they come in either 18x8 and 18x9.5 or 17x7. Which would look and fit better on a stock 95' 240sx?
ashibah83
Car: 93 SUPA BLACK COUPE
offset......but by the sizes you gave probably the 18x9.5
TwinCityTech
Car: s14 KOUKI(low n slow) s13 RB20DET(sold)
18x9.5 in the back, 18x8 up front, wouldnt match up right if u had the 9.5s all the way around-unless u had different offsets
ashibah83
TwinCityTech wrote:18x9.5 in the back, 18x8 up front, wouldnt match up right if u had the 9.5s all the way around-unless u had different offsets
why wouldnt it match up??? because they wouldnt be uber flush in back........ big deal!!!! i would rather have the option to rotate my tires than have to buy new ones every 6-12 months on a street car
ashibah83
ok i found the wheels and hers are the specs
17x7Bolt Pattern Offset 4x100 - 4x4.5/114.3 +42 5x100 - 5x4.5/114.3 +42
18x8 4x100 - 4x4.5/114.3 +45 4x4.5/114.3 +25 5x100 - 5x4.5/114.3 +45 5x100 - 5x4.5/114.3 +25 5x100 - 5x4.5/114.3 +35 5x4.5/114.3 +9
18x9.54x4.5/114.3 +25 5x100 - 5x4.5/114.3 +25 5x4.5/114.3 +15
im sticking with the 18x9.5
grffnsmth
18x9.5 all around?
ashibah83
i would say 18x9.5 all around with the +25 offset and a 225 40 18 tire maybe a 235 40 18
smocan
ashibah83 wrote:i would say 18x9.5 all around with the +25 offset and a 225 40 18 tire maybe a 235 40 18
I'd get some 5mm spacers just incase those rub on your suspension. I needed a +20 to get them to fit with my coilovers on my s13, clears by about 1-2mm.
I dont know how much more clearance you will have on an s14, might be somehting to look into or if anyone else can verify. good luck.
