Wheel size?
stb921k
Car: 1992 240sx convertible
Have 92 240 Vert and I'm getting some new rims and was wandering what would be the better size 17x7 w/ offset 40 or 17x9 w/ offset 35.
whiterps13
Car: white LE hatch
The 17x9's will be better in the long run, but your going to need to run a spacer up front to clear coilovers. To get the wheels flush with the fenders you should just run a 15mm spacer all the way around.
SeVa-S13
Car: '05 GTO 6spd
They're called wheels.Don't make titles in caps.Search, this is covered all the time.There's also a section made for this type of topic, which this will now be moved to.Thanks.
