Ke0 wrote:the wheel size is 20x9.5 offset 35
Under normal circumstances it should not be a problem. Every wheel is constructed a little different. The biggest issue will be brake calipers. But with that offset I don't think it will be a problem at all.
The wheel will stick out slightly due to the width and offset. I'm running 9.5 inches wide in the front with a +43mm offset. It's pretty darn flush bud.
I would really consider this fact, road noise will go up by about 25-30% over a 8.5 inch wide wheel. If you can go 8.5 inches in the front with a +35mm offset that would be ideal.
If you do run that wheel be sure to get quieter tires.
Best of luck...
