Wheel size and possibly spacer question
hatch-attack
Car: 1990 240sx Hb
I used to own a civic hb and I traded it for my pignose. I have a set of nice wheels that were on my civic. They are 17x8 and probally +38 or +40 My question is can I run these wheels without using any spacers? I know they will sit inside the fender and look dumb but what I want to know is there any clearance problems with brakes or anything like that. I just wanna run them untill I can sell them or whatever. I just don't wanna have to spend 250 dollars on some spacers when I can just buy the right wheels. Also what is a good offset for a 240. I was thinking like +15 or +17 would that be ok? Sorry for the same dumb question but my search did not give me an exact answer. Thanks,Adam
naed240sx
Car: .....
Are you sure they are 17x8? Most people run 17x7s on civics? Does the wheel measure 8 inches from edge to edge? If so, it is a 7" wide wheel.
If they are 7" wide, run 30-35mm spacers.
If they are 8" wide, run 20mm spacers.
If they are 17x8+38 or +40, they won't even fit without spacers.
Another thing I should add: There is no golden offset number. What is a good offset depends on how wide the wheel is you are trying to run, as well as your ride height, and tire choice.
