jdurrty »
https://forums.nicoclub.com/jdurrty-u147989.html
Fri Oct 15, 2010 3:35 pm
From what I understand I think the drivers side rotor is more of the issue than the passenger side. Gerardjg is correct, it is the wheel being torqued down that should be holding the rotor tightly in place. If the rotor is snug even after the caliper and the wheel are both removed, than the rotor is most likely rusted on to the hub assembly. Once the caliper is removed the rotor should practically fall off, so from your explanation, the passenger side rotor seems normal. The "clunk" your daughter hear is more likely the control arm bushing. These liquid filled bushings are notorious for going out especially in warmer climates, I have already gone through two sets myself. Make sure these are not the culprits first.
