18x8 +30 Front
18x10 +35 Rear
Want to know if 1) it will fit 2) what tire recomendations. Car is dropped on Tokiko white (front) Blue (rear) with Eibach springs.
Thanks Guys!
Thanks Z, So in your opinion, what would be the ideal wheel size and offset and tire combo if I wanted to have a flush look to the ZZ-owned wrote:Front size/offset isnt great and will be sunk in a bit the rear will sit flush with the outside of the fender. I run a 18x10 +35 rear with a 285/30 but given your front I would say 255-275 max and 225-245 width on the front. Depends if you want square or slight stretch.
