yes cold number (overnight with no driving).MoonlightWhite45 wrote:ok. so 37 & 39 are cold psi readings right...right now it seems im almost at 35 all the way around at start up...well thats at least the tire pressure monitors are reading....
37, 39, 40 it's all good... I would run 38psi from time to time... Then 40 psi. Heated up will be around 45psi and yes max is 50psi so you're good!!MoonlightWhite45 wrote:ok. so 37 & 39 are cold psi readings right...right now it seems im almost at 35 all the way around at start up...well thats at least the tire pressure monitors are reading....
