wheel question
skylinedreams
Car: 90 240sx
I'm just wondering if ill have fitment issues with these. the wheel size is 17 x 8 +35 I have a 90 240sx. and i'm gonna be running megan racing coilovers.
the wheel offset calculater says the clearance from the strut housing will be 20mm less and will extend an extra 30mm.
skylinedreams
Car: 90 240sx
anyone?
SmithSR
Car: 240sx
That size and offset worked fine with my coilovers, and using a 215/45-17 on front.
You'll notice that if your ride height is set way too low, the spring perch will be in line with, or hit, the shoulder of the tire.
If you have decent ride height, you'll clear just fine with the tire size mentioned above.
SmithSR
Car: 240sx
