2k5Rex »
https://forums.nicoclub.com/2k5rex-u46081.html
Wed Oct 04, 2006 8:05 am
Alright guys... I am hoping someone can shed some light on this for me... I recently bought some Panaracer C5C R1's. They are 16 x 8 in front and 16 x 10 in the rear. Offset is +35 all the way around. I also have a 300 ZX brake conversion with 30mm calipers and have converted to 5 lug hubs. The hubs in the rear are from a 300 ZX and are using the 300 ZX upright... the hubs in the front are from Ichiba. I have a 1992 240sx coupe.
Obviously I am going to need to get spacers and was probably going to get the H&R 25mm spacers with the lugs attached to the spacer.
My question though is this... the center of the wheels (that would normally sit around the hub) are smaller than the hubs themselves. Using a tape measure and my closest estimate they center of the wheels have an opening for about 57.15mm... using the same measurement on my hubs came to about 66.675mm.
Are there any spacers that will adapt to this difference (i.e., 66.675 opening for the spacer at the hub and a 57.15 hub centric lip at the wheel)?
The other option I have is to machine the wheels center to 66.675mm, or whatever the exact size is... but if I go that route, I will be adding more $$ to what was supposed to be a cheap buy in the first place. With spacers, machining, and the new wheels I could probablt pick up a used set of low offset wheels that would work without any headaches.
Lemme know if you have any ideas or insight for me.
Thanks in advance!!
