wheel problem
slip69
Car: 94 Nissan 240SX convertible
07 Dodge Charger
ok so i just had 2 new rims for the rear installed on the car. but one of them sticks out more from the fender that the other.I would say about 1-2 inches more. they are exactly the same in size and offset. anyone have an idea of why this would happen?
Modified by slip69 at 2:17 PM 6/1/2008
Eikon
Car: 71 240z, 93 Supra TT
pics please!!!
is it the rims that stick out or the tires? Are both tires exactly the same?
Are they stock 240sx rims or aftermarket?
Did you notice this in the past?
Perhaps your suspension got tweaked and the subframe is bent a bit?
GoinTopless240
Car: 1993 Nissan Sil40 Vert
2008 VW GTI
2010 Infiniti EX35 bought in 2019 (15,000) miles
did you put them on? Check the lugs and hub centering rings and make sure they are all seated correctly. You can also make sure the 4 bolts holding in the bearings are tight. I noticed that the bearings have a little spacer between the bearing and axle assembly. You can also check the sub-frame bushings to make sure nothing is bent.(rear assembly is kinda like one piece and if shifted just one inch would make one side in one inch and make other side "seem" to be off by 2 inches on other side). Hope if helps..try putting on old rims and see if they are off as well (just a thought that way you can rule out the new rims first)
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
The first thing that came to my mind was different offsets...
Strange problem you have there.
slip69
07 Dodge Charger
it was liked that before on my other rims too. these are aftermarket rims and the rims and tires are the exacty same size. i will post pics tonight when i get home. which one is the subframe bushing sorry i just dont know edit: oh and its the tire and rim that stick out. if you look at the car from the front you can see the rear drivers side wheel just sticking out a bit further than the other one. i did a carfax report on the car and its got no reported accidents. i hope this is not going to be something expensive to fix.
Modified by slip69 at 10:53 AM 5/20/2008
94_240sx
Car: 94_240SX
Man, this is a werid problem. Looks like there's some kind of damage to your subframe, you have worn out bushings or alignment is messed up. This is eccentric bolt that changes camber. If you turn this, top of your wheel goes in or out. It looks plain in FSM, but actually, there's a big chunk of metal attached to it. Maybe someone messed with it before? Anyway, I'd take it to an alignment or frame shop and see what's going on. Mine is that way too. I mean rear left and right are not the same. I installed SPL RUCA, but haven't done the alignment yet. I was going to do after z32 brake upgrade.
slip69
07 Dodge Charger
you think i should try the alignment first or mess with the bolt that changes the camber? if its the alignment should the car feel different? thanks guys for all the help
biggie
If it is cambered out that much it should fee different and bad. Get us some pics and I think someone should be able to see the problem. After pics of it on the ground it would be good to jack up the rear and take the wheels off to see any differences on each side.
DeXteR
You're going to have to get it up in the air anyway... So get the jackstands out and rest the car on them. Grab your creeper, some safety glasses, and your "head" light (everyone needs one), and inspect the all the bushings and mounting points.
Something is definitely not right. Hopefully we can help you figure it out.
onosqv
Car: '92 240sx Vert
You should know way better than this slip...
It's 99% your wheel alignment.
Unless your car was in an accident before...
slip69
07 Dodge Charger
****!! i knew it!!
brokeAs240sx wrote:You should know way better than this slip...
i swear dude i didn't even think about it being the alignment...my bad!!!
DeXteR wrote:You're going to have to get it up in the air anyway... So get the jackstands out and rest the car on them. Grab your creeper, some safety glasses, and your "head" light (everyone needs one), and inspect the all the bushings and mounting points.
i'll have to do this on sunday cause my daughters baptism party is on saturday
biggie wrote:If it is cambered out that much it should fee different and bad. Get us some pics and I think someone should be able to see the problem. After pics of it on the ground it would be good to jack up the rear and take the wheels off to see any differences on each side.
well the car doesnt fell weird at all...so im hoping its the alignment
edit: can i still drive the car like this??? i finally got matching rims and i want to show her off.
94_240sx
Car: 94_240SX
slip69 wrote:edit: can i still drive the car like this??? i finally got matching rims and i want to show her off.
I guess yes, but I'd go easy on it since you don't know exactly what is wrong with it.
onosqv
Car: '92 240sx Vert
you've been driving it like this... haha
slip69
07 Dodge Charger
yes...yes i have. just wanted to know if i should stop
onosqv
Car: '92 240sx Vert
If it makes you feel any better, my car has the same issue - actually, most people probably have this problem, but never notice it, especially on stock rims. I have a decent alignment too, but there are so many adjustable arms/bolts that it's gonna require some creativity on my part so that the alignment guys don't screw it up, haha.
I drive it, track it, hard park it, runs fine.
240DrpTop
Car: 1993 Nissan 240SX vert sold
2006 Nissan Xterra
1982 Nissan 280ZX
1984 Nissan 300ZX
I would have a four wheel allignment done. Mis-allignment will eat up your tires. Good Luck.
cmkelly
Car: 1992 Nissan 240SX Vert
2006 Acura TL
2001 Nissan Pathfinder LE
1996 Toyota 4Runner 4x4
I haven't noticed my stock rims and tires at different depths in the wheel well but my vert pulls slightly to the left even after a 2-wheel alignment. a 4-wheel was next.
On a more important note, congrats on your daughters baptism!
slip69
07 Dodge Charger
ok so i took off the wheel that was sticking out more and took pics of it on and then off. i noticed that the rear upper link is lower than the one on the other side. the one that has the wheel sticking out more is the one that has that lower. i posted pics of the part im talking about. hope those can be helpful so someone can tell me what it might be
oh and i added a pic of how close the Summit wildfire was to our house
biggie
Just looks like cambe to me.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
that sticks out alot lol
S15nS13vert
Car: 95 240sx with a s15 engine 6speed transmission, 94 S13.4 SKYLINE VERT and a 08 Lexus RX350
slip if i give you a 10mm spacer, will that cure your problem how far are you from the hollywood studio fire?
slip69
07 Dodge Charger
S15nS13vert wrote:slip if i give you a 10mm spacer, will that cure your problem how far are you from the hollywood studio fire?
yeah thanks that will cure it cosmetically our fire was in northern cal. it lasted 5 days but we had ash all over the place. schools were closed for a day cause of the smoke and ash.
S15nS13vert
slip, it is not aligment then???maybe you need to get your frame checkand i want to go to visit cali one day, even tho, there is earthquakes and fire.
slip69
07 Dodge Charger
im taking it next weekend to get it aligned. and cali is fun dude. besides its not we get those all the time but when we do look out!!!
S15nS13vert
Good luck dude w/alingand one day, i will go and visit you, and all my 240 vert fam in cali...well i will try
slip69
07 Dodge Charger
thanks dude. i'll post up results if i get this fixed soon. and your welcomed in Cali anytime
