Q45tech wrote:Never buy wheels without a lip for clip on weights if performance and vibration free driving is any concern!
Because perfection often requires a finer resolution than stick on weights and the glue - stick on adhesive won't stick to dirty used wheels.
This is somewhat true but more vibrations are caused by the tire itself, not the rim or balancing. Granted dynamic balancing is much more accurate than static but with a good tire mechanic, a hunter road force balancer and some good quality tires a smooth ride can be obtained whether the weights are clamp on or stickies.
A brick can be perfectly balanced on a tire machine with stick on weights, but that doesn't mean it will roll down the road good.
