Wheel offsets. Need help!
AntonC7
Car: 1992 Nissan 180SX
1998 Nissan Maxima SE
2005 Nissan Maxima SE
2003 Nissan Maxima SE
2006 Infiniti M35X
2012 Infiniti M56X
Hey guys,
I am about to order some wheels for my M56X. I have found 20" wheels which i personally think are gonna look great on the car. I am probably going for Niche Verona M150 wheels 20"x9 or 20"x10.5. The offset i see is the most common is +35.
So my question is what do you guys run for offset on aftermarket wheels?
Just to be clear, I have looked through rims and tires thread from before. I am running square set up (same wheels and tires all the around) and I am keeping stock suspension.
Any feedback/suggestions will be appreciated and feel free to add pictures.
I am gonna attack some pictures of what i am going for.
Thanks
Ilya
As I replied in the PM, see my build thread for images of my wheels. It's in my signature.
MY2J
Car: 2011 Infiniti M37
I had lots of trouble getting wheel info on here before as well (not trying to bash folks... people are just not very active). I can only speak from my experience with wheel specs (I own RWD) but I think the very first question you should ask yourself is stance... what are you looking for? Slammed? Flush? Camber?
With that being said, anything within the "slammed" category should consider higher offsets such as the one you mentioned for those Niches. +35 or higher will sit inside the wheel well and clear your fenders should you slam it.
Another option is to sit "flush" with the fender and in those cases I would highly recommend to stay within the mid to high +20 offsets (higher offset for wider rear wheels).
The third and final option is "camber" (VIP). I'm not too familiar with these types of set ups because major fender and suspension work must be done to fit negative (-) offsets.
ssmrico
Car: 2011 Infiniti M37 S
man I like those wheels
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
Considering you don't plan on lowering your car the 20x9 with the +35 offset will have your car looking exactly like Ilya's and is what I would recommend you go with.
To ask what others run on aftermarket wheels is a tough question because most run more aggressive offsets but are also lowered so the comparison is apples and oranges. Hopefully this helps.
Ilya
For ease of use for future members reading this, here is pics of my car with the aforementioned 20x9 +35 setup at all four corners.
Ilya wrote:Well, I finally got back home and managed to get my new wheels mounted (with OEM TPMS sensors from EBay - although those don't seem to be registering at the moment) and balanced and installed on my car.
I'm pretty happy. I *may* only need like 5mm spacers once I lower on BC's...or I might not need anything at all (would be sweet lol).
Here are the results:
Ilya wrote:Friend of mine did a little photoshoot for me because I wanted some before and after shots (before being now, after being once I lower the car and put different pipes on it). Love how these turned out.
Link to his other automotive work: CFD Productions
