wheel offset ?
jab11185
Car: 1992 Nissan 240sx
what's the offset on a wheel mean? there some that are FWD and some that say RWD does this mean that i can only use the rims that are RWD?? (the ones that i'm lookin at are FWD...)
GEO
Car: 95 240sx KA-T
liol
StockerThanStock
*giggle*
1) FWD - Front Wheel Drive2) RWD - Rear Wheel Drive3) offset - not correlated with 1 and 2
theronin
if you get wheels with offset that are higher than +30 God will smite you down
mikeG
Car: nissan 240 sx
I have yet to see an answer to this man's question. Perhaps a knowledgable chap could be of assistance?
crzycav86
Car: 93 Nissan 240SX KAT
Go do some research in the suspension forum.... the guys there won't bite or make fun of you....
jab11185
sorry....never looked into rims b4....didn't figure it was such a dumb question, but i guess that's what i get...
edit: this website seems to think that offset and RWD and FWD are connected....and i did kno that FWD and RWD were front wheel drive and rear wheel drive....i'm no dumbass...just confused by this site
StockerThanStock
Well I don't really know what offset is either, I was just pointing out FWD and RWD. Didn't mean to sound mean if I did!
theronin
im pretty sure i answered his question
s13EastTN
Car: 91 s13 hatch, 95 Honda Civic
*sigh* offset is how far out or in a wheel is compared to the car/suspension. IE a high offset wheel sticks into the car more, giving more room between the fender and the tire, and lower offset makes the wheel stick out farther, making the fender and tire closer together. Generally you want an offset below 30 or 35 for better looks and better grip. Say for example you want a 17 inch rim that is 7 inches wide, you would want something like a 17x7 with a 30 offset, I think with an 8 inch wide rim the more offset you can get away with but I'm not quite sure on how that works. Maybe this will help you out http://www.zilvia.net/faqs/offset/wheelstires.asp
AJ1356
theronin wrote:if you get wheels with offset that are higher than +30 God will smite you down
i have +32 on my s14 both front and rear . the cars handles great and the wheels and tires fit the wheel well perfectly. now the new ones i'll get would be somewehre around + or - 0 that is a totally different story. just don't hate on the 30+ or more offsets:D
theronin
are you running coilovers? what width are your wheels?
AJ1356
nuh dude , i have lowering springs tein s tech .. the tires i have are 225 andthe rims are 17x7 . i could probably fit 235s in the rear but i did not want to push it cuz the rim is only 7 inches wide. but the handling and the look of it is pretty good . and nothing rubs or hits anything and the rims are semi deep dish
AJ1356
here is a pic of what it looks like on the car
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
actually offset has to do w/ the center hub and the centerline of the wheel IIRC...look in the suspension forums for pictures and diagrams
Soy
Car: '03 Mazdaspeed Protege #295
Wayne's Wheels! Wayne's Wheels! Party Time! Excellent!
The guy obviously doesn't know wth he's doing selling rims - overpriced, mis-informed, and some pretty FUGLY lookin wheels... I'd suggest NOT buying from that site.
James
SmithSR
Car: 240sx
WHY HAVE YOU NOT SEARCHED THE TIRE FORUM FOR YOUR ANSWERS!!??!!1
Offset is the measured distance from the centerline of the wheel(the VERY middle of the wheel) to the bolt pad, ie: the spot that bolts to the car.
This distance is critical when fitting aftermarket wheels and tires, because it along with width dictate where a given tire/wheel assy will fit within the fenderwell.
Nissan's 240sx alloy 7 spoke wheel is 6" wide with a +40mm offset. It's a relatively high offset, but it's also a narrow wheel. The wider wheels require a lower offset, to maintain safe distance from suspension components on the backside of the tire/wheel assy.
AJ1356
who is selling thier wheels i don't see anyone selling here . i think we were talking about offset
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
Chet has a very good post in the FAQ about offset. The important thing to remember is the higher the number, the more it will push things in toward the suspension and the lower the number, the closer to the fenders you will be. SmithSR is right on the money for the correct offsets you should be looking at.
