wheel offset
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
would anyone happen to know the offset or lug patter on the o2 altima (2.5s) wheels, i am looking into buying NIPPON HYPERSPEED 6 wheels for my car, ive never heard of htem so i dunno, but the guy wants $475 for em, plus shipping, and they're 18s, the lug patter is 5x114.3, 45 offset, and weigh about 22lbs, only one has been mounted to check fitting, the rest are still in unopened box, watcha think???, how much of an offset should i go with?? (and of course, my dumbass doesnt even know the dam lug pattern of my car
Magnum
5x114.3mm is the right bolt pattern +45mm is the right offset for a 7.5" wide wheel.
nlzmo400r
thanks magnum, i dont know too much about wheel sizes and offsets and such, thanks for your help, but if i go with a wheel that is 8in wide (doubtful, but i dont know yet) then what offset would i need 4o??
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Offsets are my weakest area. I used to know but now I dont remember anything.
nlzmo400r
well thanks for the help :P
Magnum
18x8" +45mm would work too.
nlzmo400r
thanks, thats all i need, where did u learn the offset stuff from, is there an issue of a mag or a book i can pick up, or just from experience??
Magnum
reading and the calculations are easy. for a 8" wheel: 8x25.4 to change to mm 203.2 divide by 2 and add the offset of 45mm and you get 146.6mm (5.77") of the wheels width behind the surface of the hub and 56.6mm (2.23") infront of the hub. or you could go to http://www.discounttiredirect.com and see what they use for offsets.
nlzmo400r
well thats not that hard, i always thought it would be harder to calculate than that, thanks again
