Wheel offset question
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Sure_Shot
Car: 2008 Versa SL Tech 6speed
Would a +42 offset be fine with a 7.5" width? I just want to make sure there won't be any rubbing problems. Thanks!
blindsnyper
Car: 2007 versa
i know that 42 offset will work on 7 inch wide rims, i am sure 7.5 will work also but dont quote me
biggie
blind_snyper wrote:i know that 42 offset will work on 7 inch wide rims, i am sure 7.5 will work also but dont quote me
Assuming everything the same between the tire size the 7.5" wheel/tire is 1/4 inch closer to shock compared to the 7" if both are +42.
Sure_Shot
That's my concern. Anyone with 7.5" wheels want to weigh in?
Sure_Shot
Anyone?
Sure_Shot
c'mon
blindsnyper
Car: 2007 versa
t19uz wrote:the offset is 18x8.5 +45, its perfectly fit with the versa. No rub at all.
so the higher the offset the more wheel/tire you will have towards the inside, and the same with a wider wheel. he has a wider wheel and a higher offset...so i would say that 42 offset on a 7.5 wheel will work
Sure_Shot
Thanks! I saw that, but then in the wheel and tire database thread, Gr8dave37 claims to have 7.5s with a 45 offset that rub when they are cranked... So I wanted to be sure.
t19uz
hehe thx blind_snyper!!
Yup its totally save, no rub till now!! but don't forget do the alignment, after installing rims & spring.
Well mine its not versa but latio. I believe its same, the chassis code is C11. If u have the same code i think no rub too.
blindsnyper
Car: 2007 versa
t19uz wrote:hehe thx blind_snyper!!
yep, versa, tiida latio are all the same
Sure_Shot
Thanks guys. I'll let you know how it goes, then!
Return to “Versa Technical Discussions”
