wheel Offset Question for 240 hatch
chuckyD1
Car: 03' 350Z track edition 6spd , lemans sunset
Hey , I'm looking to get a set of sport max. Xxr 962's I'm looking to get them in 17x9 with +35 offset on all 4. Just wanted to kno how that would work couse a friend said I might rub something with that wide wheels in the front. Any info would be great. Thanks !
S14Juggalo
Car: 95 240sx (S14)
Your golden they will fit just fine no rubbing! I got the same set up on my s14 for now.
Kalypso
dont buy +35.. get the lowest offset they make. i think +15 is the lowest.
( buy something more interesting if your budget allows, everyone has these wheels. )
ectomorph
Car: 1990 240sx SE
My buddy has the same size on his 89 hatch and it rubs on his coilovers. he used 10mm spacers which made if fit a lot better and stopped the rubbing. i say go with other wheels, something with better offset and something that ISNT played out.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Kalypso wrote:dont buy +35.. get the lowest offset they make. i think +15 is the lowest.
But 9inch +35 allows a 285 tire
blacktop sr20kid
Car: 1990 240sx
frontxxr 00617x9+35(+10) w/25mm spacer215/45/17
rearxxr 96217x9+35(+10) w/25mm spacer225/45/17
Kalypso
yeah.... I suppose
mb battles are also nice.
S13Teddy
Car: R32 Skyline, S13
Well you need to be careful. Fitment is always more aggressive on a hatch, so it's more prone to rubbing.
PyroTecK
Car: 1993 240sx SE 5speed fb
i wouldnt go more than a +25 in the front w/ a 9" wheel on an s13... i have +27 and had to clear the wheel from contacting the coilover w/ a 5mm spacer. effective +22 now.
fourLUG_hero
XXR 962's suck balls.
gnvarnadore
Car: 89 240sx Base Coupe(daily/project) 91 240sx SE Coupe(sold) 92 240sx SE Coupe(sold) 89 240sx Base Hatch(sold) 93 240sx SE Hatch(SOLD!!!)
17x9+15 on my coupe with no spacers and no rubbing
gumby74
17x9 with +17 offset up front barely clears Tein coilovers. Running 235/40 r17 tires. Absolutely no rubbing on anything and still have fender liners intact.
17x9 with +24 offset running 245/40 r17's. again no clearance issues.
AZ89two4Tsx
Hope you have your fenders rolled. Be aware that you're either gonna have to run a bunch of camber or pull your fenders in the front too.
The rears will also have to be rolled, and depending on whether or not you like a bunch of camber, pulled too.
chuckyD1
AZ89two4Tsx wrote:Hope you have your fenders rolled. Be aware that you're either gonna have to run a bunch of camber or pull your fenders in the front too.
yea. I have 20 mm front vented fenders & 50 mm rear over fenders Ima be putting on after I get wheels
AZ89two4Tsx
Please don't do that.
They stick out, but not enough to require those kind of overfenders.
chuckyD1
Wel I alreadY got the fenders sooo it's not like I'm just gonna not put them on. Would be a waste of 500 plus I realy like over fenders sooo
BrianHarte
Car: 180sx
If you have those huge over fenders, you will need to space those wheels out a LOT.
OR, RUn some HUGE boy tires or something.I don't know.
Best of luck.
chuckyD1
Yeah. For the time I figure the xxr 962s are better then steelies
KC240SR
Car: 92 coupe w/ blacktop SR
I hope you have coils or something, because a stock car at stock ride hight with over fenders and wheels that don't fill the overfenders=hardcore fail.
chuckyD1
Yeah I have coilovers n wicked tuning tie rids on the car now
240lookis
Car: 1990 240sx hatch
even with a 285 on the 17x9, you are going to have to use a 50mm spacer to fill in that rear overfender.
chuckyD1
Yea if u wanna see my hatch it's on myspace.com/chaalie85 it's the lime green 1. Gonna be painting it back to black soon as the fenders n wheels are on
chuckyD1
Yea from what I see they don't make spacer bigger then 25mm , is it possible to add 2 25mm spacers onto 1 hub. That seems like a little too much tho
gnvarnadore
idk, still searching for 50mm hub centric spacers, i know you can find them for 5 lug but dont know about 4 lug
Modified by gnvarnadore at 8:18 PM 9/12/2009
AZ89two4Tsx
Good luck ruining your whole wheel bearing system if you try putting 500mm spacers on it.
25 will probably be enough for you. Just don't run any camber.
Shabbernigdo
i have 17 x 9 +20 all arround on my 91 s13 and no rubbing issues with stock suspension.
Kalypso
this thread got unusually long...
Dittoz7
Car: 1997 2f0WtY SE!
Did Someone Say...Loooooooooong?
chuckyD1
Kalypso wrote:this thread got unusually long...
hahaha , yeah it did get alot longer then i thought it would have .. im actuly thinking of running 25mm rear n 20mm front
sil8tdrftr
Car: 240SX coupe, fastback, vert
these are 50mm and the ones with black squares are 40mm and theyre 4 lug.. so they do make them
