centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Mon Oct 09, 2017 1:05 pm
Well, if the lug spins, then the threads are toast. Whether it's the stud threads, the hub threads, or both won't be known until they are separated. If this were me, I'd consider drilling out the stud with a bit equal to the inside diameter of the stud and just smaller than the threads. Then, all you have to do is clean out the threads from whatever remains of the stud. You can run a tap in there and see if the threads are still good on the hub. If the hub threads are shot, I don't think you can helicoil in this location. I think you have to replace the hub. Another options to remove the old stud, if it's loose in there, is to maybe use a 3 jaw puller and try to "yank" the stud out. If any of the threads are still good, you could take two lug nuts, put them both on and bind them up against each other, then use those to "un-bolt" the stud from the hub. Please let us know what ends up working for you.
