wheel issues
arod36
Car: 2004 nissan armada
purchased some 22 inch foose spank wheels and i have installed spacers on armada to clear caliper, but the nissan dealer is telling me that my wheels stud are to short for those wheels. not allowing lug nuts to get a good grip on wheels. they suggested gettig rid of wheels. how can i fix this? any suggestions
onosqv
Car: '92 240sx Vert
I'm guessing you installed slip on spacers?
If you did, consider bolt-on spacers (i.e. like KICS Spacers, H&R spacers, which come in bolt-on or come w/ longer studs).
Or get longer studs, such as nismo studs, which can give you an extra 15-20mm on each stud or so.
hannibal
Car: Red Line to Glenmont
Yep, bolt on spacers or longer studs. I'm not sure if Nismo makes longer studs to fit the Armada. If not, try ARP (same company the makes engine rod bolts and head studs). Ive heard they make quality wheel studs and might have something to fit your truck.
