You have to be careful when doing it up ghetto style. It's possible to strip your lug nuts, break studs or bolts, and even warp your brake rotors.Mr. Music wrote:I tighten them when the car is still jacked up. I don't have a torque wrench, so I do it the ghetto way. After I lower it, I put my foot on the lug wrench, push down and tighten it until I think its OK. Then I hope it is OK and check it every once in a while.
Yeah, I know. But its not like I over do it, just a little turn of the end of the wrench and they are tight enough. Never had any problems with it, neither has my father who taught me how to do it, lol.generic808 wrote:
Well, I do it because when you are torquing it down and the wheel is still up in the air, it may turn. Once its on the ground, its not going anywhere. Hand tighten it (as much as you can) when the car is still jacked up, and the back of the wheel should be flush with hub.spike228 wrote:Is there a reason why you torque it after you lower the car? I torque mine when its still jacked up (just in case the wheel hasn't exactly seated flush against the hub).
I tighten mine fully when jacked up, but if you've noticed, when the car is lowered, you still have a little room to play with. Next time you lower your car after your wheels were torqued, check them again and they'll still have room to reach 80 ft/lbs., or whatever you torque them to. That's just how I've done my wheels forever.spike228 wrote:Is there a reason why you torque it after you lower the car? I torque mine when its still jacked up (just in case the wheel hasn't exactly seated flush against the hub).
The "clicker" type you refer to is much more user friendly than the needle gauge. "Clicker" types are the most comon torque wrenches and they are very reliable. Also be careful when using torque wrenchs and extenstions together. Extensions increase your torque level and will do damage to your stud, if overtightenedjohnny_d wrote:side notes, some people say don't go cheap on torque wrenches, how are Craftsman torque wrenches? they have the 70 bucks clicker type one or there's the one w/ the needle for 29 bucks then there's the digital ....and forget Snap-On cuz they're way too expensive. What are u guys using?
Yes, next time try to torque your wheels when jacked up. Then, lower the car and try to torque it at the same ft/lbs and you'll see that there still is room to tighten.Mr. Music wrote:I think he means that there is more stress on the parts with the car on the ground. Like, the weight can push out on the wheel, and the lugs don't end but being as tight as they should be? Which makes perfect sense to me, but I'm just not sure if thats what he means.
Exactly! I know, it didn't make sense to me at first but after he showed me the difference, it all made sense.generic808 wrote:
