Wheel Humming
FL Q45
Hello forum! I have a 1994 Infiniti Q45 and recently I heard a humming coming from the front end of the car. If and when I am traveling above 20 M.P.H. and I turn the steering wheel to the left the humming starts (and gets louder when I turn the wheel more), but when I turn the car to the right it stops. I replaced the rack and pinion twice and I replaced all four tires with Michelin Pilot Sport A.S. 245/40/18's. Could it be in any way possible that the tie rod end can cause this humming? Can anyone inform me as to what can cause this problem???? Any help is appreciated .......
Thanks in advance
yodawill2000
Car: 94 Infiniti J30
Bearing maybe ???I have a simular situation on my 94 J30 and when I removed the wheel and turned the hub by hand I could feel a ,,, hmm , how to explain .. kinda like a grind .. the other side was smooth as silk ..I plan on replacing bothe front bearings as soon as cash flow permits
