Wheel hub assembly torque specs?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
727G35
Car: 03 Infiniti G35 sedan
I read the guide and replaced the wheel bearings, cranked them down with my large ratchet with a pipe to extend it.. I just cant find what the actual torque is supposed to be so I'm kinda nervous driving like that.
Anyone know? Thanks.
That's something you need to know, and it needs to be accurate - I don't think it requires much, which could be a problem.
infinitiservicemanual.com has the specs
727G35
Also I used the original bolts I just put loctite on them, never had a problem before, do you all think it's okay? And if it starts backing out I'd notice before it comes completely out right?
No. That's not how it works.
Do it right, because a failure means a crash.
audtatious
I know I'm late but front hubs are 65 ftlb per the FSM. Using the link above that AZhitman showed it's in the fax.pdf manual
QX1
Car: INFINITI G35 2006 6MT
Hi. Is it for G35 2006 sedan V35 6mt front wheelbearing 4 bolt torque 65 ftlbs max? Or 72 ft lbs? It is 98Nm? And for brake caliper 125 Nm. What about wheels?
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
