VitaminT »
https://forums.nicoclub.com/vitamint-u9072.html
Mon Jan 02, 2006 3:25 pm
I don't know why so many people are saying it is your suspension under low speed low load.
I have the same diff but it is really a 2way clutch deal more than that particular diff. Like some of the guys said it is completely normal. The harshness depends on how much throttle and how tight the turn.
Some say it gets better as the diff gets older but I don't drive mine that much so I couldn't say.
Also the bushings and stuff are very valid if you are launching your car, doing a burn out, spinning in the rain, ect. Like one other dude I put collars in and it got somewhat better but after recently dropping my subframe I found that one of my bushings was fully cracked.
BTW the es kit was a pretty big pita to do. I put that in with a new(er) subframe when I put my nismo 2way and 4.3final drive in. Depending on on how much you use your car you might think about the spl full subframe bushings rather than the rear es bushings. I was a little dissapointed with mine for all the work it took but then again I dont really drift or anything like that.
Modified by VitaminT at 8:26 PM 1/2/2006
