wheel hop problems! tried search already! help!
0range_240
Car: 89 HCR32
Id like to say just before anyone decides to get annoyed , that i did in fact try the search and while I did find some answers, I am still not positive as to what the problem is thats plaguing my poor 240.
Basically, I experience wheel hop when driving over bumpy roads or when accelerating under WOT off the line... it only appears to be the rear right side that is doing this... but it is quite bad at this point. I dont however experience AS MUCH if any wheel hop when cornering to the right... so is it the strut and the bushings, or just the bushings that are gone?
Exar-Kun
Car: 2005 350Z
sounds like bushings, check the shock mounts also, but it could be bushings, most 240's have soft bushings and get a lot of wheelhop.-chet
0range_240
Car: 89 HCR32
so when you buy bushings, do they come in different materials instead of the factory rubber ones?
rico05
Car: 1992 RMS13 w/ CA18DET
Yep. Most are polyurathane.
bob marley
bad shocks? bad bushings?
Dori Dori
Car: Cars of course
If your shocks are the original peices...CHANGE THEM NOW!
If you've already made some changes to your suspension, please list them.
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
Yes, what if any changes have you made to the suspension? That would help narrow things down a bit.
s13conv
Car: '86 GT-S Coupe
Maybe some Dupree subframe spacers would do the trick. ;)I installed them last weekend but haven't really driven the car to test them.
Altiman94
Car: 1989 Nissan 240SX
its your struts. Check them. Had the same problem with my 240 wheni first bought it.
Altiman94
more than likely it is the struts, that's what controls your cars up and down movements.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
had that same problem with my s13, then i got my AGX's and Pro-kit and that seemed to solve the problem for me. So my guess is that it's your strut.
s13conv
Car: '86 GT-S Coupe
Well, I drove my 240 to work today. So far, the spacers did the trick for me.
