WHEEL HELP
infinite M
Car: 2012 m37, 2013 jx35
I WANT TO GET SOME 22 FOR MY M37 BUT I KNOW THE LUG PATTERN IS 5X114 OR 5X112 THE RIMS THAT I WANT ARE 5X120 WILL THEY FIT? OR WILL I NEED SOME KIND OF SPECIAL ADAPTERS PLZ HELP DO THEY HAVE ADAPTERS THAT DONT STICK OUT CUZ THE WEELS ARE STAGGARED 22X9 AND 22X10 IN THE REAR AND MY CAR IS NOT LOWERED ... PLZ HELP INFO NEEDED ASAP I AM TRYING TO GET THESE RIMS ASAP
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
The M bolt pattern is 5x114.3. You are definitely going to need wheel adapters in order to make those wheels fit. I've only ever seen these adapters at a size of 30mm but you may be able to find thinner ones...hope that helps
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
I recommend you be patient and wait until you find a set in your correct bolt pattern... Dealing with adapters and spacers is not the best thing to do!! :gotme
Good luck on your search :bigthumb:
PlatinumM35
Car: 2006 Infiniti M35
Tein H-Tech Springs
Slotted/Cross Drilled Rotors
Wagner Ceramic Brakes
22x9 Status Wheels
Rear Entertainment Aftermarket
15'' RE Audio Subwoofer
Infinity Reference Door Speakers
Wait it out. There are so many options when it comes to wheels. Nothing works better than what was meant to fit your car. Good luck!
