marlin29311 »
https://forums.nicoclub.com/marlin29311-u97240.html
Tue Nov 18, 2008 4:22 am
welcome!
Your sizes are a little off - you should be using 235/40/19 in the front, as this is as close to the stock size in terms of diameter as you can get, and the back should be what you have it at now.
However, why are you staggering your wheel setup? On a front wheel drive setup, you are going to see no gain from having larger wheels in the back - if you are doing it for cosmetic reasons, that's fine, but you will get no benefit from having larger wheels in the rear...
I would definately wait until the snow is gone too, all that crud takes it's toll on your car after a while.
