LongBeachCoupe »
https://forums.nicoclub.com/longbeachcoupe-u74279.html
Sat Jul 12, 2008 4:30 am
a HubCentric Ring...
ok so when you put the wheel up to the lugs, it will wobble a little, the reason why is that the hub hole in the wheel is bigger, than on the hub itself...
The hub centric ring fits inside the wheel (made out of graphite, plastic, or metal) and it bridges the gap. Not required, but its really nice to have and they are cheap.. If your shaking at high speeds, this could be why.
Lugnuts depend on the seat of the wheel you are getting, most are the same, but post it here after you pick and ill let you know.
