simmode1 wrote:flohtingPoint wrote:Is tire-bite going to be a problem for him w/out a cambered rear wheel?
I'm gonna be honest: I've never heard the term 'tire-bite' before. If you're asking if his tires will rub or scrape or 'bite' the rear fenders, then I don't think he's low enough to have a problem like that. I rolled around like this for a while with no real problems... other than massive understeer:
16x8.5+27 with 30mm rear spacer, so effectively
16x8.5-3 with
225/45/16's
The car is lowered on KYB AGX's with Tein S-Tech's and stock camber. Pretty similar to the OP's setup. As you can see: the tire is
NOWHERE near the fender.
Yea, basically tire-bite is when you get chassis roll into the tire. Your fender bites into the top/side tire, shedding speed, causing uneven tire heat and damaging the tire. The tire is not near the fender, but I'm wondering if, when the chassis gets a lateral force applied to it, due to the weakness of the springs, if the roll would cause it to masticate some tire.
Krash is a budding autocrosser in my area, and it'd be a shame if he throws cash down on something that'd just hurt him in the long run, that's why I was asking.
