Well this is what I gather. They are of course 18 inch rims sorry I gotta have my rice :P, but the width of the rim is 7.5 inches.
and the spoke or mating surface of the rim is 40 mm from the center of the rim so there would be 40mm of positive offset from the center of the rim. This would mean I would have 5.32 inches of inset from the inside of the lip to the mating surface. Which is roughly 135 mm from the inside lip to the mating surface.
From my understanding a positive offset is better than negative. So in speculative terms here I have basically about 5.32 inches from the hub mating surface up to the suspension.
Now the question is does anyone know if a 5.32 inch depth from the hub assembly to the strut assembly will fly? When I go to tires.com and dial in my car these rims come up so I would assuem they would fit.
It seems to me that I am adding maybe aroudn 2 inches of depth to my rim width inward to the strut assembly. Would this fit in the wheel well? Would it rub the fender? Would it rub the inside components housed in my well? Just some good questions to throw to you guys
THANKS BTW !
