tramp_drift240 »
https://forums.nicoclub.com/tramp-drift240-u50915.html
Thu Mar 06, 2008 9:07 pm
FAIL FAIL FAIL
first off, theres a forum dedicated to wheels and suspension. this should be there.
SECONDLY, you should not plan to get overfenders unless you already have wheels that would require it.
if youre using 501's, itll be super sunken with that width and offset, and look ridiculous since theyre only 16s with a widebody steez goin on. theyre just about flush on a stock bodied s13 as it is, youd need a 50mm spacer in the back and a 20 in the front to accomodate the overfenders.
get wheels first, then plan body work necessary, not the other way around.
what're you wanting overfenders for, anyway?
