Wheel fitment question.
Tysan
Car: 1995 S14 Kouki 240sx/zilvia
18x8.5 & 18x9.5 +20F/R, 225/40F & 225/40R on my S14. I have JSK coil-overs with full adjustable camber and height. I know I will probably have to roll, but will I also have to pull as well, and will it clear the coil-overs or should I go with 215's in the front? Looking to lower the car about 1"-1"1/2 above lip of the rim as well. Don't want my car looking like 4x4. Thx in advance.
mixeds14
Car: 240
I'm running that set up with the exemption of the rear tire. Ingot a 255 35 18 on the rear tire size.. I however did have to roll and pull some because of the width of the tire n b/c my car almost has no gap between the tire or fenders. U might get away with rolling the rear with that tire size as long as u don't lower it to much ..
And ur good with the front but if u decide to lower it u are goin to have to move ur harness so ur tire doesn't rub true it.. Also if your running z32 calipers that offset will just clear them n no spacer is needed..
