compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Sun Apr 22, 2012 1:44 pm
Did you do the math and measure? Off the top of my head, I don't think they will clear stock fenders....... Not with that offset. im on 8.5 w/ 35 mm offset in the back with less than 1/2 to spare so add another inch wider rim (1/2” to each side) to that and it would be cutting it close, (like a hella flush look) then the difference of offset is another 1/2” so maybe if you pulled your fenders a good .5 to .7 inches.
The fronts you would be very close to the fender and the strut (id say within a 1/4 inch both Sides, if not rubbing.) If you have coil overs in the front, they should fit with little to no extra work.
