Wheel Fitment question
BurnsAuto90
Car: 1990 240sx
1991 240sx
ok guys, im a noob when it comes to wheel sizing...but I DID SO SOME SEARCHING.
im lookin at a set of wheels right now, and im pretty sure they wont fit without wider fenders in the front, and a serious pull/over fenders in the rear. I just wanted to double check with you guys.
sizes:
F:17x8 +28R:17x9 +38
i wouldnt mind doing a pull on the back, but i dont feel like getting into it with overfenders, etc.
any info would greatly be appreciated.
yokota180sx
Car: 1997 Stagea RS4, r34 front
onethose are weak *** offsets
two What car?
threeyou didnt search well, but its not your fault, Nico search engine needs work
4fronts wont clear coils or brakes prolly im sure
BurnsAuto90
Car: 1990 240sx
1991 240sx
yokota180sx wrote:onethose are weak *** offsets
two What car?
hey man, thanks for the info. im still trying to get the basics for wheels sizing and fitment. I think i typed in the offsets backwards. rear were +28 and the front were +38. Its a set of Blitz Z2's i planned on putting on my s13.
any tips you could give me when im looking at a set of wheels would be awesome.
Rex
Car: None
I'll offer a little more conservative perspective compared to yoko (he absolutely knows what he's talking about though).
So you mean they'reF:17x8 +38R:17x9 +28??
If so, the fronts are too high for any S-chassis car, the rears aren't too bad. But from what I've seen on cars/read you'd want to run17x8 +15-ish17x9 +20-ish
I'd recommend you find some examples of the "amount of flush" you're looking for, so people know how far you want to push it.
naed240sx wrote:Here is 17x9+20 with 235/40s and -1.8 degrees camber. My front fenders are rolled and pulled a bit.
Yours would stick out 15mm farther.
sleepyRPS13 wrote:HERE comes the spoon train...cho cho
this is what 16x8 0 offset looks like. you know if you add a 15mm spacer that would put it to 16x8 -15 offset as in Negative (same specs as the Precedeo Demon Camber Wheels).
infamous jdm rice Precedo demon camber
btw you should checkout the FAQ stickies. that should clear your confusion..
Modified by sleepyRPS13 at 9:46 AM 1/5/2007
adrians_s13 wrote:anyways... heres a few pics for ideas...
size is 18x11 +18 in the rear w/ 285; 18x10 +18 up front w/ 265
as you can see... the rears are pulled, the fronts are just rolled flat
Matej wrote:The 17x9's aren't concaved, this is what they look like.
If you want concaved, check out the 16x8 +10 Rota Grids.
eds13 wrote:17x8+8 front and rear. not bad for no fender mods (cept a roll)
I searched for threads with offset in the title in the wheels/tires subforum
yokota180sx
bullhockey
run a 9 +0and a 10+20small pull frontsmall roll rearGTG
