wheel fitment q?
el_blacky06
Car: 2007 Nissan Altima Sedan 2.5s 6MT
I'm currently running 18x8.5 on my altima sedan. Now I have a chance to run 18x10.5 all around, would this fitment be possible without rubbing or rolling fenders?
AlexM.
Car: 2010 Nissan Altima Coupe 2.5 Super Black
You will be the first to run 10.5 all around!
What I've realized is that unless you are on springs (because springs is a specifically set drop) whether you rub or not is diff for each person to an extent.
How much of a drop do you have?
What are the offsets of your wheels?
If you're on coils how much camber do you have?
IBCoupe
Car: '08 Nissan Altima Coupe 3.5SE
'19 Infiniti QX50 FWD
'17 BMW 330e iPerformance
What Alex said. Biggest question to me is offset. You need to know that. You'll be running 275 tires all around, unless you stretch them. If you're riding at stock height (or maybe even on Eibachs), you might be okay, but to be flush you'd need an offset of probably at least 55 to make it work in the front, and 50 to make it work in the rear, and I don't know what your clearance will be like inside. If you're dropped at all, I don't think I'd recommend this.
If you're on coilovers, you could camber the crap out of them, but then you're going to be going through tires every other week. :P Also, the wider the wheel, the heavier it is. Have you upgraded your brakes? You might need to, or you might need to alter your driving style to give you a lot more space to stop in the event of an emergency.
el_blacky06
Great advice thanks guys. After thinking about it, id rather not run this setup. The wheels I was looking at were the enkei pf01 18x10.5 offset was around 12. ill get 9.5 wide to play it safe
IBCoupe
Good call. I think I figured out from an amalgamation of comments made by Loop over time that "flush" is about 82.5mm out from the wheel hub in the front, and 87.5mm out from the wheel hub in the rear. (I'm sure he'll correct me if I'm wrong. You out there, Loop? :chuckle:)
If a 9.5"-wide wheel calls for, at minimum, a 245mm-wide tire, that means you'd want a wheel with a +40 offset. If it's higher, you can use spacers to make up the difference.
In the rear, that'd be a +45. But if you're going to go with stretched tires/pulled fenders/spiffy camber, you can probably squeeze out a bit smaller camber. Especially if you're not as slammed as Alex is and I used to be. :P
AlexM.
IBCoupe wrote: If you're on coilovers, you could camber the crap out of them, but then you're going to be going through tires every other week. :P Also, the wider the wheel, the heavier it is. Have you upgraded your brakes? You might need to, or you might need to alter your driving style to give you a lot more space to stop in the event of an emergency.
Camber - not true necessarily. If you bring your toe into spec then you won't be burning through tires really fast. I ran -2 in rear for about 8 months and mine were fine (I only took them off to put my new wheels on, not cause I was losing traction).
Brakes - Good point! When I had my old wheels they were only 8.5 wide but super heavy! Noticed a huge difference in braking. If you're going with a more expensive wheel then the difference in braking power is less drastic I would say.
IBCoupe
Agreed. Either you're going to pay for it with the better wheel or you're going to pay for it with the better brakes.
And if you really want to do it right, pay for it with both and just rest easy!
el_blacky06
Id choose to pay for the better wheel since I do care about the weight lol my current setup my wheel only weights like 20 pounds each (just a guess) with a +38 offset. Now I want wheels that are agressive to change the look & overall style since I'm getting my car painted pearl white this upcoming week. Thanks a lot for the info guys, I learned a bit more about wheel setups
AlexM.
Looking forward to your paint job! I wanna go white too lol
Theiranman69
Car: Super Black Altima Coupe '08, CVT
I ran 18x 9.5 with a +15 with no problems rubbing.... but the wheels stuck out about an inch... I've also run 19x 10.5 same offset with the wheels sticking out more lol. if you want i can try to find some pictures from a while ago.
Ricko
Car: 2008 Altima Coupe
Yeah please lets see some pics. I was thinking about getting some wheels off a friend of mine.
18x8.5 (40 offset) -Front
19x10 (42 offset) - Rear
Might be too much but we are going to put them on and see whats up.
alphapig
Car: Nissan Altima Coupe S 2.5
19x10 +42 sounds delicious
The front will need some spacers for sure though, too much poke in the rear and not enough in the front doesn't look that good on our cars
Theiranman69
well i was running a 19x 10.5 with a +15 offset, so it might be a little different than a +42
I did this just for fun, i took them off of my brothers evo. :biggrin: also these were put on when i was still on springs.
Ricko
Dang, yeah those might be a bit much haha. I would have to do a lot of fab to make them look good.
i still might just put them on for s***. I will take pics and post when I do it.
mattyfo0z
Car: 2oo8 CVT - 3.5 SE
That second picture makes those wheels look HOT. A little less poke and some negative camber and they would fit really well :bigthumb:
el_blacky06
Damm! Good thing I didn't get the wheels or else there goes my track runs lol still looks sweet for those who want wide wheels
