wheel fitment........help.....
jeu510
Car: 73 datsun 510, 90 300zx na, 06 m35
i am in the process of buy some wheels for my 94 convertable which i had already done the 5 lug conversion....i need to know how wide i can go without any fender mods.....i also need to know what offset i need to get...i'm planning to get either 18's or 19's.....i want it to look hella crazy but to where i can still be able to drive without problems.....thanks ahead.....
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
now that you have the convertion compleate..you need to find out the offset for the new convertion....the offset will drasticly change the footsetting...you need to be shure the offset you choose wont change the dynamic of your suspention to a setting you dont want sire....goood luck.
smurf13
Car: 1992 Nissan 240SX fatback
im guessing by your sig you have a s13. And if you dont want to look too crazy just do 17's. do you have coilovers? and with decent camber and ride height a 9j +15ish is cake on a s13. a very slight strech (sayyyy 225/45/17) and you should be set.
adrianfromthecastle
Car: 1992 Nissan 240sx
liquid_cool wrote:now that you have the convertion compleate..you need to find out the offset for the new convertion....the offset will drasticly change the footsetting...you need to be shure the offset you choose wont change the dynamic of your suspention to a setting you dont want sire....goood luck.
um... yeah... changing the hub doesn't necessarily change the offset of the wheel or where it sits inside the fender, unless the hubs aren't pressed in correctly or something....
jeu510 - read the "wheel fitment thread" that's stickied up top of this forum. It gives wheel specs and tire specs, and also provides pictures to give you an idea. Specifically, check out Broadfield's s13. He has a pretty wide wheel/tire set up on virgin fenders.
