Wheel Fitment: Center Bore HELP
NPR300
Car: 1994 300ZX Coupe 5-Speed (30k miles)
I recently purchased some aftermarket wheels with a 64mm center bore. I now realize that the Z32 has a 66.1mm hub :facepalm:
Are there any reasonable options for me? 5mm spacers would make it work but would eliminate the hub, leaving the wheel to rest solely on the studs (would that cause problems?). Having them machined would be too expensive, and they could still end up not fitting perfectly...
Any suggestions?
