wheel fitment 240sx with z32 F/R brakes
chuckd502113
i have a 93 240 with f/r z32 brakes will 16 X 7 33 offset front and 16 X 8 33 offset rear clear the calipers rims are Tanabe Precedeo Wheels
poshatch
Car: p.o.s. 1990 240sx hatch
those dimensions are pretty fail...had to get that out of the way
they look like they MIGHT be able to fit them
are you running 30mm or 28mm?
chuckd502113
30mm alum calipers
DuckyD
Car: 1995 240SX
Honestly, don't know.
The stock Z32 wheels have higher offset but a different spoke design that is further out towards the face of the wheel (allowing for better brake clearance).
Edit: I agree.. 16x7+33 isn't very cool.
poshatch
the 30mm are pretty wide, the 28 mm will clear the stock se wheels by like literally a hairs width
so these wheels might pose a problem, if there was a pic from the rear of the wheel that would help more but my vote is for NO
now if you SET on these wheels what im about to suggest may shock some people
if you NEED to run the wheels to drive and have no other solution, then use some washers to space it barely but ONLY if you got enough thred left and MAX 3 washers, just until you can afford spacers and what not
otherwise just dont get the wheels :biggrin:
