Razi »
https://forums.nicoclub.com/razi-u53191.html
Thu Jul 22, 2010 6:22 am
No, every mm you add with a spacer, you're subtracting one more from the offset.
Lowering offset = closer to the fender
Yeah, if you want your tire to sit close to the fender, measure the distance from the fender to the tire and that's the thickness of the spacer you want.
If it's too thick though, you'll need longer studs.
Also, if your spacers are thick make sure they are hubcentric, if it isn't, the weight will rest on the studs instead of the hub and you could strip your studs and you know how bad that ish can turn out.
