Modified by maxentropy at 2:14 PM 6/20/2008adidas2go wrote:I have 19x8, 235/35/19. If i had the choice again i would go 245/35/19
Yep.maxentropy wrote:So you take the overall diameter divided by 2 (or the radius) of the new tire and subtract it from the same from the OEM and you get the difference in height that your car will sit correct?
The 245/40/19 will give you a little more ground clearance.maxentropy wrote:Thus, if I want more space between my car and the pavement I should go with the 245/40/19 or the 235/40/19?
