The new Wheel FAQ! Yay!
The Tire Rack Home Page
The Tire Rack Tech Center
Tire Rack Accessories Guide
Tire Rack Wheel Guide
Other links & stuff:
Wheel offset calculator What does offset mean?*stock offset is 40mm on S13/S14*
Wheel weights Provides a great collection of wheel weights by diameter, but does not tell you weights by width(so it may be off on certain wheels because of width differences)...still a good 'rule of thumb' type guide to what wheels are worth buying for weight saving purposes.
More wheel weights and specs Like the site above, provide lots of useful wheel information, weights, bolt patters, finishes, etc.
Wheel Information stock specificationsBOLT PATTERNS (Torque spec).4-lug: 4x114.3 (72-87 ft/lb)5-lug: 5x114.3 (72-87 ft/lb)THREAD SIZE: 12mmx1.25
1991 S13 7 Spoke Alloy Wheels (SE Model ones)15x6 with a 40mm offset
1996 S14 5 Spoke Alloy Wheels (SE Model ones)16x6.5 with a 40mm offset
1992 Z32 Twisty Alloy Wheels (Non Turbo) (1991)16x7.5 with a 45mm offset
1992 Z32 Twisty Alloy Wheels (Turbo) (1991)16x7.5 with a 45mm offset - Front16x8.5 with a 35mm offset - Rear
Wheel Specs from other cars that may fit a Nissan Courtesy of(the man!) SmithSR
Other Nissan Car Specs
Vehicle model('M' = Medium Offset)... model years.. wheel sizes..bolt pattern.. hub bore
NX2000/ Pulsar/ Sentra........'88-00... 13/14".. 4-100 59.20mmSentra/ Pulsar FWD..............'83-87....13" ........4-4.5... 66.06200sx(M)...............................'77-85....13/14"...4-4.5... 66.06200sx FWD...........................'94-01....13/14"....4-100...59.20240sx/200sx FWD.................'85-97.....15"....... 4-4.5....66.06240sx/200sx .......................'88-98.....15/16"... 5-45.....66.06B210/510/610/710RWD(M). '68-83.....13"........ 4-4.5....66.06240z/260z/280z/ZX RWD(M).'70-85....14/15"... 4-4.5....66.06280zx/300zx(M)....................'86-89.....15/16"....5-4.5...66.06300zx Turbo(M)....................'90-96.....16"..........5-4.5...66.06300ZX non Turbo(M)..............'90-96.....16"........5-.45...66.06310 FWD/ F10/ Stanza.........'79-89.....13/14"....4-4.5....66.06350z(M)................................'03-.........17/18"....5-4.5....66.06810/Maxima(M)....................'79-84......14"........ 4-4.5....66.061600/1800 RWD(M)..............'66-70.....14".........4-4.5....66.06Altima................................'91-01.....14/15"...... 4-4.5....66.06Altima.................................'03- .........15/16".....5-4.5....66.06Maxima.............................. '85-88......14/15"......4-4.5...66.06Maxima...............................'89-03......15/16".... 5-4.5... 66.06Sentra................................'01-03......14-"..........4-4.5...66.06Stanza................................'90-..........13/14".....4-4.5....66.06
Infiniti vehicles:G20 .....................................'91-................14/15".....4-4.5... 66.06I30/I35 ................................'95-................15"..........5-4.5....66.06J30 .......................................'93-................15"..........5-4.5....66.06M30 .......................................'90-...............15"......... 4-4.5....66.06Q45........................................'90-03.........15/16/17"..5-4.5....66.06M45 .......................................'03.................18".........5-4.5....66.06G35........................................ '03................17/18"... 5-4.5... 66.06
Other Manufacturer's specs usefull for Nissan'sNo Acura(even though the bolt pattern matches on many)
No Alfa Romeo
Amc uses a 5-4.5 RWD on it's '57-87 Ambassador, AMX, Concord, Gremlin, Hornet, Javelin, Marlin, Pacer, Rambler, Rebel, and Spirit. The AMC Eagle and Spirit 4WD from '75-89 use a 15" 5-4.5
No Audi
No BMW
No Buick
No Caddy
Chevy NovaII from '62-67 uses 13/14" 4-4.5 70.30hub boreCorvair 4 lug (but not 5 lug) from '60-64 uses 13" 4-4.5 70.30 hub boreChevy Sprint from '88-89 uses 12/13" 4-4.5, 59.61hub boreOlder models not included
Other than that, no Chevrolet uses the 4 or 5-4.5 bolt pattern
Chysler:300M....'97-03....16/17"......5-4.5.....71.50hub boreConcorde/LHS/New Yorker FWD...'93-.....15/16"....5-4.5....71.50Conquest RWD...'84-85....14/15".......4-4.5.....67.06Conquest RWD...'86-94.....15/16"......5-4.5.....67.06Laser..................'89-........14/15/16"...5-4.5.....67.06Sebring(excl. convertible)....'95-....14/15/16"....5-4.5.....67.06Older models not included
No Daihatsu
Daewoo Leganza...'98-....15"........5-4.5.......56.60
Dodge:Avenger(excl. convertible)....'95-....14/15/16"....5-4.5....67.06Daytona(laser)......'89-.........14/15/16".......5-4.5.....67.06Intrepid.................'93-.........15/16".............5-4.5.....71.50Stealth FWD..........'91-..........15/16"............5-4.5......67.06Stealth R/T AWD Turbo....'91- .....17".....5-4.5.....67.06older models not included
Eagle Summit FWD....'89-91....13/14"....4-4.5......67.06Talon FWD/AWD........'90-......14/15/16"....5-4.5....67.06TSIFWD/Vision...........'93-......15/16".........5-4.5.....67.06
No Ferrari
No Fiat
Ford:Crown Vic/LTD RWD.....'90-03...15/16"....5-4.5......70.50Crown Vic.....'03.........16"..........5-4.5....................70.50Mustang........'92-03......15-18"...5-4.5...................70.50Probe............'88-92......14-16".....5-4.5..................59.61Probe............'93-01......14-16".....5-4.5..................67.06older models not included
Geo metro from '88-01 used 4-4.5 but with 59.61 hub bore
No Honda(although bolt patterns do match)
Hyundai:Accent.................'95-99..........13"..........4-4.5.........67.06Elantra/Sonata....'89-..............14/15"....4-4.5.........67.06Excel/GLS/Scoupe...'86-...........13/14"....4-4.5.........67.06Tiburon.................'97-03..........14".........4-4.5.........67.06Tiburon.................'03................15"........5-4.5.........67.06
No Isuzu
No Jaguar
Kia Optima.........'01-03.......14/15"......4-4.5......67.06
Lexus uses too small a hub bore. 60.06.
Lincoln:Town Car.....'80-94..............15"......5-4.5.......70.50Town Car.....'95-03..............15/16"...5-4.5......70.50older models not included
MG: MGA/MGB.....'63-81.......15"......4-4.5......?hub bore
Mazda: many of these hub bores are too small. be advised.Mazda "6".....'03......16/17"......5-4.5.....hub bore:59.61rx-8..............'03.......18"..........5-4.5......59.61323/GLC.......'82-89...13/14".....4-4.5.....59.61626fwd.........'84-87....14/15"....4-4.5......59.61626/MX6.......'88-92.....14/15".....5-4.5....59.61MP3/Protege...'01-03...16/17".....5-4.5....59.61626/MX6fwd.....'93-.......14-16"....5-4.5.....67.06929..................'87-........15/16"....5-4.5.....67.06Millenia.............'95-........15/16"....5-4.5.....67.06 rx7 GSL/GTV......'86-92....15/16'....5-4.5.....67.06rx7 GSL/GTV Turbo...'86-92..15/16"...5-4.5....67.06rx7 turbo...........'93-........16/17".......5-4.5......67.06(Medium offset)
No Mercedes
Mercury:All models from..........'48-54.......15"..........5-4.5.......?hub boreGran Marquis.....'89-03.......15/16"............5-4.5.......70.50Marauder...........'03.............17/18"...........5-4.5.......70.50older models and models with smaller hub bore not included
No Merkur
Mitsubishi:3000GT FWD........................'91-01......15/16".......5-4.5......67.063000GT Spyder FWd/AWD...'92-01.......15/16".......5-4.5......67.063000GT VR-4 AWD...............'92-01........17/18".......5-4.5......67.06Galant/mirage/Tredia FWD...'83-92.......13/14".......4-4.5......67.06Diamante..............................'91-03.......15"............5-4.5......67.06Eclipse FWD/AWD.................'89-03....14/15/16".....5-4.5......67.06Galant..................................'92-97......14/15".........4-4.5......67.06Galant..................................'98-03.......15"..............5-4.5......67.06Lancer OZ.............................'01-03.......15".............4-4.5.......67.06Starion RWD.........................'84-86.......14/15".........4-4.5......67.06Starion RWD.........................'87-93........15/16"........5-4.5......67.06
No modern Oldsmobile....get it?
No Opel
No Peugeot
Plymouth:Laser...........'89-........14/15/16"........5-4.5........67.06Prowler.......'97-.............18"F/20"R......5-4.5........?hub boremodern listings only. Older(pre-'80) not included
No Pontiac
No Porsche
Saab:99/900........'72-86......15"........4-4.5.....?hub bore
No Saturn
Sterling:825/827/SL........'86-91......15"......4-4.5....?hub bore
Subaru SVX....'91-......16".......5-4.5......56.16
Suzuki uses 60.06 hub bore. While the models Aero and Swift use a 4-4.5 blot pattern, the hub bore is too small to fit the 66.06 Nissan hub. No fit.
Toyota:most all toyota cars use smaller hub bore than Nissan, hence the wheels no fit! Several cars such as the '75-85 Celica GT RWD use 4-4.5 bolt pattern with a 60.06 hub bore. No fit. Avalon uses 5-4.5 with the same 60.06 hub bore. Again, good bolt pattern, bad hub bore. Others:Cressida, Corolla RWD, All Supra incl. Turbo use 60.06 hub bore. Every modern Toyota uses 60.06 or even smaller 54.06 hub bore. None will fit the 66.06 Nissan hub.
No VW
No Volvo (65.07 and 67.07hub bore, but the 67.07 hub bore wheels are the wrong bolt pattern)
More to come later!-Chet
