Wheel experts, need help with offset on Work and SSR rims on a S14a!
YellowFellow
Car: Nissan 200sx S14a (Europe style) Sport Line
I badly need some help from you guys out there! I have a simple stock body S14a with Tein Flex coilovers, and I need some help with offsets on Work Meister S1 and/or SSR Professor SP-1 in 18inch!
What to choose? If you see my list under here, I found these cars and sizes on rimtuck.com, but which offset should I go for? My car is a daily btw, and I dont have any plans of stylingkit...
Work Meister S1 3 piece
• (Front) 18x9,5 +3 and (Rear)18x10 +12 (#296)
• (Front) 18x9,5 +1 and (Rear) 18x10,5 +12 (#634)
• (Front) 18x9 +5 and (Rear) 18x10 -5 (#387)
• (Front) 18x9 +16 and (Rear) 18x10 +18 (#401)
• (Front) 18x9 +14 and (Rear) 18x10 +0 (Quail from NicoClub, SXOC)
SSR Professor SP-1
• (Front) 18x10 +16 and (Rear) 18x10 +24 (#260)
• (Front) 18x9 +? and (Rear) 18x10 +? (http://maydaygarage.com/2009/0...40sx/ )
Modified by YellowFellow at 3:56 PM 2/17/2010
Gabes13
Car: rb20det s13
YellowFellow wrote:• (Front) 18x9 +16 and (Rear) 18x10 +18 (#401)
YellowFellow
^^ Yeah? This is the best offsets of these? No more or less? Or should I say "the perfect fitment" on a S14a?
No need to add spacers? Do you know what kind of disk I should run?
E7-S14
Car: ess 14 foo!
disk?
• (Front) 18x9 +16 and (Rear) 18x10 +18 (#401)those sizes will workbut you Will have to Pull your rear QPs and roll the fronts. Thats with a 245/40 REAR and a 225/40 FRONT.
Reference Shot:F- 18x9 +16 225/40/18R- 18x10 +18 245/40/18
Rear is pulled ~5mm, front is rolled.
YellowFellow
E7-S14 wrote:disk?
A DISK = Standard diskO DISK = Deep rim diskL DISK = Big caliper diskR DISK = Big caliper disk
What about 18x10,5 in the rear with the right offset? More pull in the back than 18x10 or pretty the same?
Modified by YellowFellow at 1:25 AM 2/17/2010
Gabes13
Car: rb20det s13
Fitment is subjective. Kind of like paint.You can't please everyone. From personal experience, I would enjoy the quoted size.As for disk size, depends on your brakes.IIRC, A disk clears most stock brakes. If 18x10 +16 needs a pull, then 18x10.5 +16 would need a pull also.0.25" more.
YellowFellow
What about this setup in SSR Professor SP-1 18x9 +11/+3/-7 in front and 18x10 +11 or 18x10,5 +18/+5 in the rear? And which tire size and brand to them? Btw, I have stock brakes around.. Maybe I have some plans for the front in the future?
Will it clarify my Tein Flex coilovers? Too much pull?
Modified by YellowFellow at 8:49 PM 2/20/2010
