2002sentragxe wrote: I just wanted to know if I have to bleed the brakes since I am going to be installing them my self?
Yes, you will need to bleed them. There is no fluid in the cylinders when you put them on so you will need to get all the air out or you will end up with a very mushy pedal and the brakes will be ineffective.
2002sentragxe wrote:Also is it hard to install the wheel cylinders?
It is not too difficult to do. Just take your time and have the correct tools on hand. Make sure you have plenty of brake clean on hand as well. Brake fluid is a PITA when you get it on your hands and tools.
