Wheel crack (pothole) - new sizing help needed
maxentropy
Car: '08 Altima Coupe 3.5SE
Hey guys. I've currently been running the following configuration:
19x8 wheels with +30 offset wrapped in 245/40/19 tires
One of my wheels just cracked due to a major pothole and I'm thinking of buying 4 new wheels since my offset is a tad too aggressive.
I'm thinking of keeping everything the same size but go with a different offset to pull the wheel and tire into the well a little more.
Check my math but I believe a +45 offset should tuck my wheel in 15mm or .59" more than where my wheels are now.
I could simply replace the cracked wheel with the same +30 offset but I'm thinking now is a good time to go all out and get the extra tuck I want.
nogears909
Car: 2008 Niagra Grey Coupe 2.5S CVT
+45 is the stock offset
maxentropy
I know +45 is stock offset but my wheels and tires are not stock size.
alphapig
Car: Nissan Altima Coupe S 2.5
May i suggest running a wider tire rather than getting higher offset?
With 19x8, to achieve "stock" offset, you need +50 or higher, to account for the .5in wider-than-stock wheel. With high offset like that you might end up rubbing on your suspension, or on the inner fender.
I would stick with something moderate like 19x8+25 to 18x9+35 and run fat tires like 255/40/19.
maxentropy
@Shift Pig --
I'm not looking to achieve a stock size/setup-- just making sure that my calculations are correct that my wheels would tuck in .59" which would allow me to clear the fender.
Would 19x8 wheels with +45 offset wrapped in 245/40/19 tires have any clearance issues with the suspension or inner fender? I have no problems with my current setup of 19x8 wheels with +30 offset wrapped in 245/40/19 tires with the exception that if I have weight/people in my back seat my rear tires will rub on the fender over bumps.
I want to eliminate that completely by switching to a +45 offset -- if that would clear everything on the inside.
Thoughts?
alphapig
19x8+45 won't have any issues
It will just look really sunken :gotme
