hammertime »
https://forums.nicoclub.com/hammertime-u119960.html
Tue Jan 06, 2009 8:01 am
I just mounted Linea Corsa LM 19's on my 08 G37s and the front do not clear the calipers. I tried a 10mm spacer and then 2 -10 mm spacers. The 2 spacers almost cleared but the lugs would not tighten down. I thought about using longer studs and more spacer but am concerned about clearance to the fender or vibration. Looks like it will take about 25-30mm spacer to clear the caliper. FYI: the caliper is the stock Brembo that comes with the 08 S package. Any advice or experence with this?
