nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Thu Aug 01, 2013 10:19 am
What I was trying to say, it will look the same on 18's, the offset and width are the same as the 19's, end result will be the same rim wise. Tires will be just a hair larger in the sidewall.
40 series is the height of the sidewall. I have 255/35-18 on the rear. It has a slight slant/stretched look, 40's will be larger. 225/40-18 will give a stretched look and keep the same diameter on a 18. You should be able to get away without a pull, but you will need a roll so it doesn't chew up your tire.
Are you talking the concave look in the rim? Depends on the type of rim you get, all rims do not have that look. But the look will be the same at the edge of the rim. Yes, offset lower in the rear with same width, will be aggressive or look more flush to the body lines.
