Wheel calipers all rusted...HELP (2007 Infiniti M45 Sport)
vhilts
07 M45 Sport (17k miles); body has been washed and waxed religiously since i bought it...
but all four wheels have rusting calipers (rotors are fine)... it looks terrible!!!
anyone else having the problem? $50k car one would have expected stainless steel or some other alloy to stop the problem.. do Lexus' look like this?
come on Infiniti get with the program...
RAGTPZ
Car: 1993 Nissan 300ZX Twin Turbo Convertible, 2010 Infiniti FX50S
vhilts wrote:07 M45 Sport (17k miles); body has been washed and waxed religiously since i bought it...
Simple solution, clean the calipers with an wire brush to get off the rust off and then paint with your color of choice. Unless painted or powdercoated all calipers will rust essentially. Some manufacturers do it from the factory, most don't. This should take you maybe a couple of hours if it's your first time and cost less than $20.
Mark Linkous
Car: 2012 Infiniti M37x
Hello,My calipers are afflicted as well. With the Sport wheels, I am sure you can see the oxidation quite a bit. Refinishing is the way to go.Randy, is the color of your car Desert Platinum (KX4)? It looks to be the same color as mine. I think you would be the only other member with that color. It was only available in 2004, replacing Golden Sand.Cheers,mark
RAGTPZ
Mark Linkous wrote:Hello,My calipers are afflicted as well. With the Sport wheels, I am sure you can see the oxidation quite a bit. Refinishing is the way to go.Randy, is the color of your car Desert Platinum (KX4)? It looks to be the same color as mine. I think you would be the only other member with that color. It was only available in 2004, replacing Golden Sand.Cheers,mark
No, it is Diamond Graphite.
