Wheel bolt pattern
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
chadg
Car: 2007 G35X
The bad news... I have to get rid of my 2004 350Z Second child comming and I have yet to find the double decker baby seat.
The good new is that I'm looking to replace it with a 2007 G35X. My question is: Should I keep my after market wheels I bought for my Z? Does anyone know if the bolt pattern is the same and I can use them on the G?
Thanks, and I'll post pics when I get it....
Chad.
JeromeS13
Car: 2008 Subaru Impreza STI
The bolt pattern is the same. However, the lower offsets typically found on aftermarket wheels for the Z are too low for the G Sedan. What are the sizes and offsets?
-Jerome
chadg
Car: 2007 G35X
Thanks Jerome, I'm not sure what you mean by offset? How would I measure it?
JeromeS13
Its usually stamped on the backside of the mounting surface (to the wheel hub). Its usually marked as simply "+30", etc.
But, you could also measure it to get a rough estimate:
https://www.rsracing.com/tech-wheel.html
-Jerome
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
