Wheel bolt and nut problem
boznuttz
Car: MS13
I just put on my new wheels, and, I'm having a few problems. The bolts aren't long enough, but I can easily solve that problem with longer wheel studs. As for the bolts, they are a little on the short side, and I can't fully tighten them down because they recess too far into the holes. Is there a such thing as nuts with a longer length to stick out of these holes more?
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Yeah, I know a guy with an Integra that has some extended lightweight lug nuts. Don't know where he got them though. Their like half the size of your finger I'm talking loooonngggg!!!
boznuttz
Car: MS13
I was browsing the SPL website and found these: Gorilla chrome plated small diameter 1-piece lug nuts are steel which meets most club racing requirements (aluminum lug nuts are usually not recommended). small profile makes these lug nuts reasonably light and fit with wheels with deep/small bores. Set of 20 lug nuts, 12mmx1.25 to fit Nissan lugs, with 1 adapter tool.
Can I use these on the oem wheelstuds? Because if so....my problem is solved!
JeromeS13
Car: 2008 Subaru Impreza STI
Yes, you can, as long as you get the correct thread pitch.
-Jerome
positron1
Mine look like that only shorter.
