Shaftinator24 »
https://forums.nicoclub.com/shaftinator24-u159405.html
Thu Jun 23, 2011 1:15 pm
Alright guys this is seriously killin me! I'm replacing a bad rear passenger side wheel bearing and I have taken everything off except the wheel bearing is tough! Any tips on getting the wheel bearing off?? I've tried pounding it with a sledge, putting the 19mm bolts back in the front side and tapping the bearing out that way..I dunno what else to try really? I had someone suggest getting a torch? What do you guys think? The hub assembly basically broke off from the wheel bearing, and the race inside the wheel bearing was broken with metal chunks and balls lying all over the place inside of the assembly. I dunno what I did but I'm assuming I may have hit a curb too hard?? Anyways any ideas would be great I have a whole new hub assembly with a good wheel bearing.
