tja623 »
https://forums.nicoclub.com/tja623-u242128.html
Mon Apr 27, 2015 8:01 am
Hey jiggersplat, the ABS sensor is very easy to remove. 1 bolt , and pull/slide it out of the way (which you must do in order to remove bearing assembly without damaging the ABS sensor). No need to replace ABS sensor with wheel bearing. However I did look at what Rock Auto is offering. I believe the ABS sensor they are talking about is the ABS ring built into the bearing itself, which they all should have. That ring is what the actual ABS sensor gets its signal from-small notches in the ring pass by the sensor at various speeds , telling the sensor/ECU how fast each wheel is moving. The difference is the QUALITY of the bearing. Trust me, go with the better brand, OEM or Timken. These wheel/hub bearings are prone to damage especially if you hit a large pothole at high speed....Then the infamous howling begins. $80 is the average price for the proper wheel/hub bearing assembly.
